O2 sensor stuck in the manifold!
Old Mar 13, 2007 | 06:27 PM
mrmint69's Avatar
I just put headers on the car and i went to remove the old O2's and the drivers was loose and the passenger is so damn stuck i cant remove even if i stand on the wrench. I think i would destroy it if i used the force necessary to break it loose. Can i use any spray or will that foul them? I was hoping to use the old ones till the new headers get broken in and don't foul a brand new one.
Old Mar 13, 2007 | 06:44 PM
2000GTP's Avatar
If you have access to a torch, try heating them up and then break it free.
Old Mar 14, 2007 | 05:05 AM
exgmguy's Avatar
Heat the metal around the sensor. Try to keep the heat off the sensor. Usually a good 30 seconds from a torch will let them loose.
Old Mar 14, 2007 | 03:19 PM
mrmint69's Avatar
I like heating the pipe as opposed to the sensor. Probable better chance of it surviving.
mightymouse383
Jul 20, 2016 07:34 AM
tds1213
Nov 27, 2014 12:55 PM
Jul 4, 2005 05:00 PM
91Bird305
Aug 8, 2002 12:36 AM
Fusion93Z
Jul 29, 2002 06:13 PM
