need help with loudmouth...please
Old Dec 19, 2007 | 09:57 PM
95blackz28_89's Avatar
ok so i really need someones help ive been trying forever and i just cant firgure it out, maybe im just really dumb. i cant connect the pipes the right way, the arent fitting,. can someone find me a some better instructions or can tell me how to connect the piping?
Old Dec 20, 2007 | 12:46 AM
Kaj's Avatar
Kaj
make sure that the small pipe that has a small rolling offset is correctly positioned, otherwise your driveline will make short work of your new exhaust. The small pieces are connected as in the diagram to the bullet muffler.
and sometimes the over the axle connection is a bit off so you have to bang around on it to work.
Old Dec 24, 2007 | 04:08 PM
thanks bro, i figured it out my self but it was really hard becase i couldnt get my car high enough lol
but my buddys father has a shop so after i got it on we took it there got it on a lift where we cojuld tighten a little more and adjust things that when i tried under my car id hit my face a good 3 times lol
but your right i had to bang around and **** and get it off the drive line.
Old Dec 24, 2007 | 06:18 PM
Kaj's Avatar
Kaj
another thing you need to watch is that if you're not welding it, the over the axle connection can get blown out really easy, so I'd recommend getting it welded at all connections with the muffler and then where the tailpipes meet, otherwise you're bound to have some major exhaust leaks.
