Need flex-pipe for V-Bands?
Old Feb 6, 2009 | 11:07 PM
TasTe GOOD's Avatar
I'm going to be installing 2 V-band clamps at the end of my Slp Mid Headers and I was wondering, do I need to install some sort of flex pipe on the Y-Pipe? If so, where?
The reason why I am putting v band clamps on is because one bolt hole on the 2-bolt ball and flange is stripped (driver side) and one on the passenger side siezed as I tried to loosen it up.
Because of the stripped 2-bolt flange, I am getting a real bad leak, causing me to get headaches and bad o2 sensor readings (I am assuming from what I have read about header leaks and ses light I am getting after install...)
Old Feb 8, 2009 | 07:22 PM
1redTA's Avatar
jdkf
I have V-bands on my FLP headers they seem to be fine w/o any flex couplers. I asked this question my self and was pretty much told no, get some poly motor mounts and you'll be good. Besides, the inside of the flex don't look like they flow that well.
Old Feb 12, 2009 | 12:56 AM
TasTe GOOD's Avatar
Well that's good to hear because I have poly mounts already. Does anybody else out there run v-bands with poly mounts and no flex pipe?
Old Feb 21, 2009 | 07:53 PM
DelSoto's Avatar
everything is tacked in those pics....they got tig welded. Poly mounts all around and no issues
Bobczar
Oct 23, 2015 11:22 AM
Henson071
May 14, 2013 03:12 PM
ddr698
Jun 16, 2010 10:32 PM
SPANKY LS1
Nov 13, 2005 07:50 PM
