My Z28 Exhaust stock (vid)
Old Apr 17, 2008 | 03:36 PM
Red93Camaro's Avatar
lol...Bone stock, Too quiet...I have Some mods commin, Hooker LTs, ORY, SLP LM1s aw yeah.
http://www.youtube.com/watch?v=4pT7RctbCRM
Old Apr 17, 2008 | 04:03 PM
2000GTP's Avatar
I haven't heard a stock exhaust in a long time. It doesn't sound bad though for factory. Add a 30 dollar exhaust cutout and it will really wound good.
Old Apr 17, 2008 | 04:05 PM
Only 30 bucks? I thought it was at least 200? Or is that for a good Electronic one?
Old Apr 17, 2008 | 04:07 PM
2000GTP's Avatar
Correct, that is the electric one. Just a plain cutout will run 30 bucks, the stainless steel version around 45.
Old Apr 19, 2008 | 04:26 PM
anyone have any other opinions?
Old Apr 19, 2008 | 05:00 PM
cn97z28's Avatar
Get a CAI also.
Old Apr 19, 2008 | 07:02 PM
2000GTP's Avatar
Originally Posted by cn97z28
Get a CAI also.
Yep, a mail order tune will add some power to and is very cost effective. Might even want to look into doing some suspension upgrades.
Old Apr 19, 2008 | 11:34 PM
Any name brands? etc? how much would a mail order tune cost and is it easy to do?
Old Apr 20, 2008 | 02:19 AM
slomarao's Avatar
100 for a pcm4less tune. 50 for a re tune. I used them for a while but there are many others.
Old Apr 20, 2008 | 11:12 AM
2000GTP's Avatar
Yes. Also, www.madz28.com is the other big one that many people, including myself, use on this site. It is pretty easy to do, basically the tuner will send you a tuned PCM. You then remove your existing PCM and send it back to the tuner as the "core." Removing the PCM is an easy 10 minute job, nothing to it.
Old Apr 20, 2008 | 12:56 PM
I would also like to tune my Fans so the low goes on Around 160 or something instead of the stock 200 something. Or am I better off gettin a 160* stat and the manual switch for the fans?
Old Apr 20, 2008 | 01:54 PM
2000GTP's Avatar
You can do a manual switch, PCM tuning will do the same effect. With the PCM tuning, you can have other parameters changed though as well. A mail-order tune is usually good for a 10-15rwhp gain.
Old Apr 20, 2008 | 03:13 PM
6SpdLT1Z's Avatar
Sounds like my '97 Z did.
Old Apr 20, 2008 | 03:35 PM
So I should get a mail order tune to make my fans go on at 160* plus I'll get the switch?
and that Mail order tune will add 10-15rwhp? or I have to have the m.o.t. set to different things?
Old Apr 21, 2008 | 10:11 AM
2000GTP's Avatar
The tuner will adjust other parameters as well to net the power gains. As for the fans, you will either do the tune or the switch, not both. It is a matter or preference in which one you choose. If you went with the PCM tune though, you can basically nail two birds with the same stone as the fan on/off temps can be changed as well as a few other things all for one pricetag.
