Magnaflow Install?
It's a piece of cake once you get the old exhaust off. You'll need to cut the stock pipe where it goes over the axle. No real specialty tools though. I'd say 2 hours tops, if you have little mechanical ability.
what you mean quick an painless iam doing mine an the pipe off the cat is welded so you gota cut it. so iam cutting the pipe b4 the cat using a adapter to the new cat i bought then welding the new pipe from the kit to the new cat then clampin the rest of its way. also i got the 3" pipe from the cat back
iam cutting it right b4 the cat off the y-pipe then using a 3"swell pipe adapter then to the new cat then the magnaflow 3" catback pipes an i just bought a cut out an gonna install it right b5 the pipes bend over the rear end. also can u pass emmissions with a cut out? if its covered with the cap?
I have a cutout on my car, I just capped it up before taking it in. With the car being noticably louder, I didn't want to attract any attention to the underchassis. I don't see an issue with installing it now, just cap it off when taking it in.
You shouldn't, there should be a gasket there anyway. My QTP cutout had a gasket, it is basically a 3-bolt collector gasket so they are pretty easy to find and buy if you don't have one.
All you need is an impact wrench with a chisel bit. And go to town right before where it bends up over the axle. With an impact it took me about 5 minutes to knock the stock exhaust right off. Easiest way to do it imo. Then the install is cake...
When i did my magnaflow, the hangers didnt line up correctly so i had to make new ones. I know someone else that had the same problem, but it sounds like most ppl dont. Just throwing it out there even though its wasnt really a big deal to make it fit
drptop70ss
May 4, 2015 08:22 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
