Installing headers need a lift?
Old Apr 2, 2007 | 09:27 PM
CamaroRacing12's Avatar
do u really need a lift to SAFELY install longtubes? i want to install my longtubes and dont know really how high im gonna need to get the car.... any input would be nice.... also wat 02 sensors and extensions do i need to buy?
Old Apr 2, 2007 | 09:37 PM
95LT1conv's Avatar
you dont NEED a lift. i had the front at about 2.5'. just get a good set of jackstands all around and you'll be fine. i've also heard that if you pull the valve covers, both sides can go in through the top
Old Apr 2, 2007 | 10:03 PM
reamo04's Avatar
we did it with jackstands all around. Driverside from the bottom, passenger side from the top.
buy o2 extensions from thunderracing.com
Old Apr 3, 2007 | 07:44 AM
2000GTP's Avatar
You have to get the car up very high in order to get them in. Just make sure the car is safely supported on jackstands, safety is key. I would stick with AC Delco sensors and 12" extensions should do the trick as well. If your headers are coated, I would drive around with the old sensors for at least a week and break them in. Then put in the brand new sensors. You can probably snag the sensors from one of these guys for a really good rate: http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
BPS
9
Mar 5, 2015 10:51 PM
dmcdonald96
Jan 30, 2015 06:46 AM
kandied91z
Jan 23, 2015 11:14 AM
