Hooker Shorties vs PS LTs
Alright. I know everyone swears by Pacesetter LTs and everyone has em.
But I have a technical question.
As far as the difference in Torque/HP of the two.
Will I see more low end torque coming in the curve with the LT's verses the Hooker Mid Lengths?? Or vice versa??
I'd really like to know what the technical difference is between the two in relation to torque and HP.
Thanks all!!,
Ivan
Sidenote.....I have the Hooker SuperComp Mids with ypipe sitting here that a friend gave me. About a year old. Free...?? Change things???
Thanks all!!,
Ivan
The whole idea of "long tubes" is the longer primaries, which improve low end torque, compared to shorter primaries. You get more grunt on the bottom end. Peak torque and the point at which it occurs generally will not change - that's determined mainly by primary diameter. High RPM torque may actually be reduced with longer primaries.
That's the "theory".... but whether it works is going to be more a matter of the specific engine setup, the rest of the exhaust setup, whether you are comparing the same primary diameters, whether an effort was made to make the primaries equal length, etc.
Simplified explanation:
http://www.carcraft.com/techarticles...ics/index.html
Thank you Fred.
The Mid/Shorties/Freebie will be installed then.
I can't see the justification for the extra money I'll spend and I'm sure that these have got to be better than the stock crap I've got on there now.
Excellent reply.
Thanks,
Ivan
Excellent reply.
Thanks,
Ivan
RUENUF
Mar 13, 2016 03:37 PM
Devinfoote87
Jul 30, 2015 09:54 AM
colts0455
Jul 28, 2015 11:28 PM
