Headers/exhaust is hitting ....
Old Jun 20, 2010 | 01:12 PM
Drkbwtiprfm25's Avatar
Well I've been trying to fix the minor problems with my exhaust. Now I've hit a snag and not sure what to do. The passenger side header was sitting on the K-member and the y-pipe on the drivers side was against the transmission cross-member.
I replaced the motor mounts and it brought up the header about 1/4 to 1/2 an inch off of the K-member and gave me maybe a 1/4 gap from the cross-member. At this point I figured that my problem had been solved. Well I went to take it for a test drive. It no longer hits when you put it into gear. However, if you give it more than 1/4 throttle starting out you can feel it hitting the floor again. Only for the initial launch tho. Once your moving the spots don't hit any more.
Where do I go from here? Will it hurt the strength if I grind out/notch the k-member where its hitting the header? How much room do I really need for flex? If anyone can give me some advice it would be appreciated. Thanks
Old Jun 23, 2010 | 07:08 AM
Stainless Works's Avatar
Whats the specs on the car? Whos headers and y pipe are you using?
Old Jun 23, 2010 | 12:32 PM
95 Camaro LT1 A4
I used energy suspension mount inserts. I have Jethot LTs and a hooker y-pipe
Old Jun 24, 2010 | 08:31 AM
Honestly, I would say there is something wrong with the header. If the car is factory, without any crazy sub frame mods or aftermarket heads, they should clear everything.
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 10:09 AM
Hal Fisher
Sep 30, 2015 09:03 PM
SergheiS
Sep 29, 2015 08:56 PM
alliance12364
Sep 23, 2015 12:40 PM
