flowmaster 40s 40buks new
Old Oct 25, 2008 | 09:42 PM
wichol98's Avatar
Question flowmaster 40s 40buks new
my fraind is selling me 2 new flowmaster 40s can i use them on my 94 lt1
Old Oct 25, 2008 | 09:50 PM
sn8ke eatr's Avatar
lt1s use a Y pipe; 2 pipes merge into one, then they split back into 2 tail pipes after the muffler. the factory lt1 muffler is located behind the rear end, they have 1 inlet on the passenger side, and 2 outlets, 1 on the drivers side and 1 on the passengers side, each leading to an exhaust tip.
your simplest option would be to eliminate the stock muffler, and use 1 of the 40's and only have a single exhaust exit on the drivers side of the car.
in order to use both mufflers, you would have to fabricate a true dual exhaust system. its not easy however it can be done, and there are pictures on the board to help you out should you decide to go that route, but be aware that in the long run it will probably cost more fabbing up an exhaust then its worth to save like 40 bucks on the muffler.
personally, id throw 1 of them on there, have 1 exit, no big deal. then save up for a set of longtube heads, a nice Y pipe, and a quality cat-back exhaust made just for your car.
good luck,
Formula Steve
Sep 19, 2023 08:31 AM
HibachiZ28
Nov 6, 2015 12:53 AM
football4life
Oct 4, 2015 07:48 AM
Formula Steve
Sep 19, 2015 08:48 PM
Sep 11, 2015 09:44 AM
