Exhaust for my 85 Z28
Old Apr 24, 2008 | 08:52 PM
mike85z28's Avatar
Since I can't put duals on my 85 Z, what is my best option for a kick *** exhaust? I'm thinking, eliminate the cat and running 3" stainless into a Flowmaster with 3" outlets??? Also there are so many mufflers that are "performance mufflers", I want one that is deep and throaty. And with the least amount of restriction. Thanks!
Old Apr 25, 2008 | 08:24 AM
teke184's Avatar
who says you can't run duals on an fbody? pretty sure i have 3" duals on mine
run a 2.5" xpipe setup with 2 magnaflow 4x9 mufflers...you'll like it
Old Apr 25, 2008 | 05:51 PM
mike85z28's Avatar
The shop said you cant because how it runs up in along that channel or whatever it's called. Do you have pics of your set up?
Old Apr 26, 2008 | 05:48 PM
teke184's Avatar
find a new shop.
its a custom job...but not THAT hard.
you'll lose some ground clearance, but really not that much if you go with 2.5" pipe. i've got 3" and i only scrape a couple places around town...and barely.
get the universal Xpipe setup from summit or jegs, a couple 24" bullet mufflers and dump it before the axle.
unfortunatly i don't have any of it in the car...hasn't been on a lift in years.
here is one of the exhaust pulled out when i did my clutch
from behind
best shot i have of clearance
Old Apr 26, 2008 | 06:01 PM
mike85z28's Avatar
Thanks man!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Jan 5, 2015 07:14 PM
rockync7
Jan 1, 2015 05:10 AM
