Exhaust Leak? Any tips/tricks
For the past couple of months I have a faint odor of exhaust coming through the fresh air vents (I have an aftermarket hood with an open cowl by the windshield) - particularly if the HVAC is set for outside air upper vent). It is really only noticable when I stop and have the windows up - cant smell it at all in motion. I do get a particularly bad blast immediately after a morning startup. I have smelled around under the hood and I seem to detect a faint oder from the pass side bank - but with the alternator creating air turbulance its tough to tell.
I can't imagine it's too far down the line cause the morning smell is immediate - NOT like its creeping in from somewhere. Anyone have any tricks for finding a leak?
They make a machine that puts a white smoke in your tailpipe, and it will leak out where you have a hole. The machine is really expensive but you can use a fog machine if you have one or if you know if anyone else has one, it works just as good!
Hope that helps.
M
Hope that helps.
M
^ I like that idea..
I've allways used the method of having a friend w/ a fist full of rags cover the tips for short periods and you can roam around underneath and listen/look for leaks. Watch for black suit or black marks around the connections.
I'm getting it underhood. I have looked over the connections underneath and they seem good. I'm guessing exhaust manifold? I was able to get about 1/8 turn on the pass rear bolt - but the others are all but inaccessible without disassembly.
I don't know about the soapy water on the manifold - it's stock and I can't see low enough for that to do any good.
I do like that smoke in the tailpipe - that sounds cool - if I could make it work.
usually i just listen real close and i can locate and then feel where it is leaking though
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
Brake_L8
Jan 20, 2015 09:44 AM
