Electric cut-out?
Electric cut-out?
A few questions for you guys running electric cut-outs. Do they seal up nice when their closed or sound like a small exhaust leak? Are they pretty dependable if the car does not see rain or winters? Does it stop on it's own when you open or close it? I already have a regular cut-out unstalled. Can I just use that one and install the electric part? Are the bolts on a regular cut-out removable if I need longer ones? Thanks for any help.
I have an electric qtp cutout. A single cat-back with 1997 383 - D1 Lt1 motor. It seals fine. I fabricated my own pipe with the Y, and, a turn down before the axle. I ended up using 3/8 threaded rod pieces with lock-tite on nuts to secure. The fasteners do lossen up with time and heat cycle. I have to re-tighten up alot of the fasteners on the qtp and the mount @ least once a year. You do not want to overdrive the electric motor, but the electric feature is quite nice. Don't drive the car in winter. Hope this helps.
tdigger9899
Sep 7, 2015 10:56 AM
