any of you use the bolts and gaskets that came with the pacesetters?
Old Jan 28, 2008 | 01:14 AM
BlkZ28Kreepn's Avatar
well finally ordered my long tubes, just wondering how many of you used the gaskets and bolts that came with the long tubes? if not whats a good gasket/bolts to go with?
thanks for any help.
Old Jan 28, 2008 | 07:34 AM
2000GTP's Avatar
The old gaskets Pacesetter used to use were pieces of paper crap. I threw those right in the garbage. I did use their bolts however and I haven't had any problems, I tightened them once and they have never backed out on me. I do periodically run a wrench over them to double check though. From what I hear, they are using better copper gaskets now.
Old Jan 28, 2008 | 09:02 PM
mrmint69's Avatar
I bought a set of copper ones thinking i was getting paper and ended up returning them since the ones it came with were very nice. I did buy the copper y-pipe flange gaskets since they are paper. The bolts need tightening 4 times and the last 2 were only 2 bolts with very little movement. I went back months later and they were all solid. The ones in the kit worked well. I did use sealent on the gaskets and have zero leaks from them.
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
