Z06 clutch in LT1
Old Jun 21, 2004 | 09:34 PM
MadaSnik84's Avatar
Z06 clutch in LT1
Looking to buy that Z06 flywheel, pressure plate, and clutch disc kit from gmpartsdirect.com for $300ish. I was wondering if anybody knew if the bolt patterns were different on LT1 versus LS1/6 cranks.
Are there any physical differences in the sizes of the pressure plates that would make it not fit in the bellhousing of my LT1 transmission?
Old Jun 22, 2004 | 08:24 AM
GREGG 97Z's Avatar
You cant use an LS1/LS6 clutch/flywheel in an LT1. If you want to upgrade to a "Corvette" performance clutch go with an LT4, the pressure plate has more clamping force and it uses a stronger unsprung disc than the LT1. Better yet I would just go with SLP's clutch kit, I've used it for 10k hard miles and its worked great so far.
Old Jun 22, 2004 | 04:24 PM
MadaSnik84's Avatar
So I take it the bolt pattern on the crank for the flywheel is different between the two then?
Because that would be the only reason they dont work from what I've gathered off this site. LS1 discs work in LT1 setups so the spline count and shaft diameter are the same.
I dont really need a stronger clutch, or a new one at all right now. Just since I'm replacing a shot transmission, I figure I might as well put a new clutch set in while I'm at it.
I don't need a "Corvette" clutch, just thought that if it would bolt up it would be a great deal since you get a new flywheel and everything for $300.
Old Jun 22, 2004 | 04:27 PM
dave96dcm's Avatar
LS1's are a push type, LT1's are a pull.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
HectorM52
Jan 30, 2015 11:08 PM
hotrodyou1
Dec 20, 2014 10:05 PM
siguy
Nov 27, 2014 10:07 AM
