WTF. Is this true?
Old Jun 20, 2004 | 06:45 PM
warwickbass's Avatar
WTF. Is this true?
"All LT1 F-cars with automatic transmissions also have a transmission oil cooler as standard equipment. The transmission cooler is an oil to water type mounted inside the RH radiator tank."
Read that from some site. I have a ****ing transmission cooler on my '95 Z28 A4?
Old Jun 20, 2004 | 07:25 PM
dreamer1q's Avatar
Yes it is true. Look on the right tank, that is where the trans lines go in. It helps, but not as much as a aftermarket one will help.
On a side note, I have often wondered if you could make the factory trans cooler work for a oil cooler. Now that I have a M6, it is still there but not being used. Wonder if I could run the oil thru the old Auto trans cooler holes and route it back.
Old Jun 20, 2004 | 11:32 PM
Loadre's Avatar
Some LT1s came with a built in oil cooler.
Old Jun 21, 2004 | 08:31 PM
Yes, RPO code KC4.
RUENUF
Mar 13, 2016 03:37 PM
generaldave
Sep 25, 2015 06:48 PM
Slayer
Aug 17, 2015 03:55 PM
meissen
Aug 11, 2015 06:05 AM
