Won't downshift
Old Apr 25, 2014 | 06:37 AM
Chet1185's Avatar
Won't downshift
I put this here because it may be a sensor or something engine related.
Car won't downshift into second if im going over 35 mph. Any idea what would cause this? I believe the car has 3.23 gears. I was told to drive in third gear at 70 mph and whatever the rpm is, is what gears i have. This is in my 95 z28 a4. Thanks in advance.
Sent from my LG-LS860 using Tapatalk
Old Apr 25, 2014 | 07:51 AM
Re: Won't downshift
Did you scan if for codes? There are numerous codes for the transmission, and they don't turn on the SES light.
Did you check the service parts tag for the rear axle code (GU2 = 2.73; GU5 = 3.23)?
Old Apr 25, 2014 | 08:02 AM
Chet1185's Avatar
Re: Won't downshift
I did not scan it. I will, as i do have the free software from here. Also did not check for the axle code. I thought all a4 came with 2.73?
Old Apr 25, 2014 | 08:36 AM
Chet1185's Avatar
Re: Won't downshift
It is GU5. And there are no trans codes.
Old Apr 25, 2014 | 10:19 AM
Re: Won't downshift
The standard rear on the Z28 with the A4 was 2.73. There was an option (GU5) for a "performance rear axle", and that got you 3.23's.
If you hold 3rd gear at 75 mph with 2.73'S YOU WILL GET 2,735 rpm, with 3.23's you would get 3,235 RPM. That's assuming the 25.7" tires (245/50-16). If you have the 26.1" tires (235/55-16) you would have to drive at 77 MPH.
Old Apr 25, 2014 | 10:23 AM
Chet1185's Avatar
Re: Won't downshift
Cool. I didn't know that.
So what does that do that makes it different than my TA with the 2.73's?
Old Apr 25, 2014 | 10:47 AM
Re: Won't downshift
If you want, I can move this to "Drivetrain" where Frank from CPT may be able to answer the question.
Old Apr 25, 2014 | 11:01 AM
Chet1185's Avatar
Re: Won't downshift
Sounds good. Thanks
68camaroboltz
Oct 5, 2015 01:46 PM
Hal Fisher
Sep 30, 2015 09:03 PM
KYWes
Sep 26, 2015 08:49 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
