Will Ford gears work in Chevy?
Old Nov 2, 2004 | 11:27 PM
Silvershark's Avatar
I was talking to a buddy of mine and he said that Ford 3.73 gears and 7.5 ring gear would work in my camaro. I know that I can get GM 3.73 gears and 7.5 ring gear for my chevy. The theory makes since, but I just didnt know if they were cut different per ford and chevy. If someone could clear this up I would apprecaite it.
Thanks.
Old Nov 2, 2004 | 11:49 PM
Z95m6's Avatar
Re: Will Ford gears work in Chevy?
I highly doubt it. I'm sure the amt of bolts on ring gear are diff and diff, spacing. Also the length of the pinion gear i doubt is the same too.
Old Nov 2, 2004 | 11:53 PM
Thanks for the clarification.
Also I have a M6 Do I have a series 4 carrier?
Old Nov 3, 2004 | 12:22 AM
1BAD86Z's Avatar
different pinion and carrier bearings, pinion seal,crush sleeve, ring gear bolt pattern, pinion offset from centerline of differential,cover pan bolt pattern,pinon flange is a 4 bolt flange and gm uses a u-joint with straps,bolt pattern on alxe studs. i think i got them all? any questions, i work at AAM. keep buying GM trucks, keep me in a job. thanks...
Old Nov 3, 2004 | 12:23 AM
AL SS590 M6's Avatar
Moderator
3series
Old Nov 6, 2004 | 02:17 AM
Doh. Well I guess I will pass on a good deal to someone here then.
Came across these on Ebay. I do not know the seller, I just though this was a good deal.
http://cgi.ebay.com/ebaymotors/ws/eB...e=STRK:MEWA:IT
ChrisFrez
Jan 11, 2015 03:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
ChrisFrez
Nov 30, 2014 08:41 AM
