Will this center section/3rd member be okay?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2433062804
I know its sold but the seller has more, I was wondering if something like this would hold close to the same amounts of power an aftermarket center section would hold, like a moser or strange. I will be using the moser housing but I don't want to buy a center section new.
In a word, no.
This is a stock, lighter duty center section with small bearing bores
and probably the stock pinion support. It would "probably" live
indefinitely on the street with moderate power if it's properly set up. If you plan on serious power and a capable chassis for any
track use, do yourself a favor and don't skimp on the center section. The 1st time you blow the pinion gear out and your
driveshaft smacks you in the ***, you'll wish you had.
RX Speed Works
Aug 20, 2015 03:40 PM
