Wheel stud safety problem..?
Old Nov 6, 2006 | 03:54 PM
T/A-Bob's Avatar
I was changing out my DRs for winter driving today, when I noticed there's about 2 threads less engagement of the lugnuts on the rear wheel studs compared to the front. I have Superior aftermarket stock replacement axles and it looks like the wheel studs are shorter than stock. I have stock wheels and stock lug nuts.
I've been driving it this way for over 5 years - just noticed it today - question: is this a safety problem? Should I have the rear wheel studs replaced with ones that are longer?
Old Nov 6, 2006 | 04:28 PM
The requirement for safe thread engagement is that the length of the thread engagement, in the hex portion of the lug, should be "one diameter" of the stud. In other words, with 12mm or 1/2" diameter studs, you want 1/2" of thread engagement. More is OK. Less is not good. If you have at least 1/2" of threads on the stud engaging 1/2" of threads in the lug, you are OK. That requirement includes some sort of "safety factor".
Old Nov 6, 2006 | 05:21 PM
T/A-Bob's Avatar
Thanks, Fred. In my mind's eye, it seems like there was less than 1/2 inch of thread engagement. I'll go out tomorrow and measure it.
Old Nov 7, 2006 | 07:00 AM
Do your replacement axles have press-in studs or threaded?
Old Nov 7, 2006 | 11:54 AM
T/A-Bob's Avatar
I don't know. Would it be obvious when I get a wheel off, or is there some other way I could tell? (haven't had a chance yet to measure it)
Old Nov 7, 2006 | 03:12 PM
If they are knurled/press-in, the heads will be flat and round. If they are screw-in, the heads of the studs will have a hex head so you can tighten them into the axle hub flanges with a wrench. One reason for asking - the threaded ones will sometimes back out a little when you tighten the lugs, leaving them a bit shorter than they should be. A little lock-tight and periodic tightening helps with the screw-in studs.
Old Nov 7, 2006 | 04:33 PM
T/A-Bob's Avatar
Great info, thanks again. Looks like I will have a chance tomorrow (going to be in the 60s) to check it out.
Old Nov 8, 2006 | 12:54 PM
T/A-Bob's Avatar
Well, this certainly doesn't bode well... the studs are press-in, and the amount of thread engagement is 0.31 inches (measured pretty carefully with calipers).
Time to replace the studs?
Old Nov 8, 2006 | 05:05 PM
Seems very short. How long are the studs? I'll measure the factory ones when I get home.
Old Nov 9, 2006 | 12:45 PM
Stock press-in stud is 2.14" overall length.
Unthreaded end: 0.34"
Threaded length: 1.15"
Shoulder: 0.19"
Knurl: .30"
head: .16"
Assuming the knurl fills the thickness of the hub flange, the projection of the stud would be 1.68"
Old Nov 11, 2006 | 04:42 PM
T/A-Bob's Avatar
This does not look too good...
The total projection of the stud is 1.09". The unthreaded part is approximately 0.38". This leaves the length with actual threads of approximately 0.71" -- this is a full 0.40" shorter than stock! I wonder how these "stock replacement" axles (from a reputable company) could have wheel studs this short?
I am quite certain that the stud is fully pressed in from the back.
Old Nov 12, 2006 | 07:18 AM
526 SS 96's Avatar
Just get a set of ARP 3" studs, I think they are $8 a side. Just poound the current studs out with a hammer, and pull the new ones on with a lug nut and some washers stacked behind it (note an impact wrench helps alot). I would however get a couple of extra lug nuts, you will probably start chewing up the threads in the lug after 10 studs.
Good Luck.
Old Nov 12, 2006 | 11:27 AM
T/A-Bob's Avatar
I think you're right. It's worth changing them out just for the peace of mind. If the current studs are so marginal, I'm thinking why take any chances...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Jan 23, 2015 01:13 PM
Ken95Z28
Sep 15, 2002 12:37 AM
