What are some simptoms of a bad clutch?
I took it to a few places and 1 says my clutch is going bad the other say the clutch may be O.K. it might be something else.
it smells like if i were driving with the E-brake on, but i'm not, just like burnig brakes.
if i do need to change my clutch what parts should be changed besides the clutch disk?
by the way it's a '96 Z28 M6 w/ 39,235 miles on it no Mods and probably not to many to come.
Studders or no pull on acceleration(similar to misfiring plug) I get a smell from bad traffic and my clutch is a new dual centreforce. Make sure the clutch bearing is replaced. I remember my stock clutch would slip a lot but also told it was normal, I did have a few bolt ons and couldn't deal with it anymore. My clutch when they pulled it was gone.
PS. Curious, do you have a noise at the flywheel when sitting with the clutch disengaged?
Originally posted by Yoges_96_Z28
thanks for tje response, but there's
No Noise, no hessitation, just a bad metal burning smell, no smoke,
Where can I get a slave cylinder from??
About that slave cylinder, you can get an entire pre-filled clutch hydraulic assembly from GM Parts Direct.com or from a dealership. Its most likely not your hydraulics though. If you need to replace your clutch, you'll need a new pilot bushing, a new clutch disc, a new pressure plate, and a new throwout bearing (those usually come with the pressure plate). You'll also need your flywheel resurfaced. Do a search on this topic, you'll find a ton of info.
