what rearend fluid do I need?
Old May 17, 2005 | 05:44 PM
Pyro97's Avatar
My car has a rear from a 2000 trans am. It has 3.73's and the limited slip or whatever. I am changing the fluid and installing a TA cover. What fluid do I need? Do I need any additives or anything since it's limited slip?
Old May 17, 2005 | 09:34 PM
magnumv8's Avatar
Re: what rearend fluid do I need?
some 90 wt gear fluid with a bottle of GM limited slip additive.
You must use the additive with the limited slip.
Old May 17, 2005 | 09:58 PM
Z06Z28's Avatar
I used Mobil 1, 75w-90 with gm additive.
Old May 19, 2005 | 12:58 PM
brians96Z's Avatar
I used Wolfs Head oil with Kendall additive, and have had no problems.
Old May 20, 2005 | 01:10 AM
slomarao's Avatar
lucas oil with gm addative.
Old May 20, 2005 | 03:17 AM
Pro Built Automatics's Avatar
I agree, the Lucas oil & GM additive works the best for the money.
93 RedBird
Nov 15, 2015 08:24 AM
blac94Z
Nov 4, 2015 01:59 PM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
