What other cars is the short 700r4 in?
Old Dec 28, 2003 | 10:06 PM
nuck's Avatar
Replacing the existing tranny in a friend's 1984 Z28. There are apparently 2 different lengths of 700R4 with the Camaro having the short one. What other cars have the shorter tranny?
Also, if you are rebuilding it anyway, does it matter if you use the older model(which I am told is much weaker)?
Old Jan 13, 2004 | 09:10 AM
camrat68's Avatar
Late '80's 9C1 Caprice's (cop cars) used the short tail shaft 700R4's. You can also get the tailshaft to convert any long tail shaft to a short tail shaft. It was GM part#8673406. I'm not too sure if that's still a valid part# though.
Old Jan 13, 2004 | 10:44 AM
mongse_1's Avatar
I had a friend who used one from an '80s 4x4 Suburban. Not sure if he switched tailshafts, but the car ran 10.30's w/ it in there.
Old Jan 14, 2004 | 06:53 AM
Pro Built Automatics's Avatar
All 700R4's in Camaro's & Firebirds are the same length, the Corvette's are about 1" shorter, and use a different tail housing. The only other one is a 4WD type, which has no tail housing.
Cam's maro
Dec 28, 2014 09:30 AM
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
CaRParts102
Dec 6, 2014 08:45 AM
Lederman1976
Nov 30, 2014 05:21 AM
USAirman93
Nov 24, 2014 03:37 PM
