What gear do I have?
Old Aug 13, 2006 | 12:12 PM
98blckz28's Avatar
I know on the door of my car it says I have 3.23's. But this is not the stock rearend in the car. The woman that had it before me had it replaced. So if someone could give me some engine rpm speeds or whatever for the gear i would appreciate it. I have an A4
Old Aug 13, 2006 | 01:27 PM
MyShibbyZ28's Avatar
Re: What gear do I have?
go 76 mph in 3rd gear (1:1). Whatever the RPM is at, that is your gear. Example: 3400 rpm = 3.42 gears or 2700 = 2.73.
Old Aug 13, 2006 | 01:39 PM
Jazsun's Avatar
I though 4th gear was 1:1??
Old Aug 13, 2006 | 01:41 PM
OBE1 95Z28's Avatar
In an A4, 3rd gear is one to one. In a M6, 4th gear is one to one.
Old Aug 13, 2006 | 03:20 PM
2001NBMZ28's Avatar
Check out one of the calculators - www.f-body.org/gears/
Old Aug 13, 2006 | 07:46 PM
Dave '97 Z28 M6's Avatar
That is really neat! That's gotta be the easiest way for people to figure out their gear ratio if they're unsure.
Old Aug 13, 2006 | 10:21 PM
Jazsun's Avatar
The only problem is that not everyones spedo is the same and some can very upto 10mph. Not sure if that would effect the 76mph thing or not but sounds like it would throw it off.
Old Aug 13, 2006 | 11:03 PM
That does not effect this way of testing the gear ratio. If you have different gears and the speedos are off, then the RPM will be different, resulting in a different gear ratio.
Also, who wouldn't notice their speedometer is off by 10 mph? If it is off by 5 then still no biggy. the RPM will be close enough to tell you what you want to know.
Old Aug 14, 2006 | 12:39 PM
87DJP2001's Avatar
If you are not sure of your rear gear ratio, pull the cover and count the gear & pinion teeth. Or the easy way check the ratio stamped of the ring gear OD. Other methodes are guess work.
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
