what to do next
Old Mar 25, 2004 | 01:43 PM
CamaroZ28LT1's Avatar
what to do next
ok i know after removing the everything and putting the clutch back in, how do i shim it so it goes into gear right, plus when i can i bleed the clutch? and another question i am young and stupied and while unplugging the sensors i didnt label them how do i know where each one goes?? thanks
Old Mar 27, 2004 | 07:26 PM
lillbush5555's Avatar
shim it?? Slid the tranny in just about all the way...put the shift fork on, then slide it the rest of the way. Bolt it up and ur done...As far as bleeding the clutch the only way to bleed LT1's that I know of is to sit there and pump the pedal like 5 billion times with it all hooked up,,,as far as sensors they should all be right near the spot the plug into..put the harness up there and you will see which 1 is closest to each sensor.
matt
Old Mar 27, 2004 | 11:28 PM
zx1216's Avatar
the sensor plugs are all different so there is only one spot to plug them in.
