What is causing my annoying vibration? and will a Denny's Driveshaft help?
Alright 2 or 3 years ago I installed a Moser 9" rear end. I went from 3.73 gears to 4.22 gears. I hope I remember correctly by saying the vibration started after that. It starts vibrating at 65mph or so and higher. I have the stock steel driveshaft. I have heard numerous people saying going to real low gears can cause it and that you need to change driveshafts. I've also heard that you just need a high speed balance done to your driveshaft. Could it be something else? Keep in mind I do have a frame mounted torque arm as well. Which I know will cause me to feel some vibrations but why just above a certain mph. Also will a Denny's nitrous driveshaft get rid of this? Does anyone know what is causing this. Thank you sooooooo much for any help.
ddr698
01-31-2015 10:58 AM
