weird 1-2 shift, 700r4
Old Sep 10, 2006 | 10:11 PM
confused327's Avatar
the 1-2 shift in my 700 is bad, when it shifts at WOT there is a bit of a flare and then it rather slowly shifts into 2nd, at partial throttle it does the same thing but to a much lesser extent. all of the other shifts are ok, but not as good as the th350 i used to have in there. could this be caused by a bad spring bleeding off pressure? the fluid looked and smelled good, and there was no crap in the pan.
is there any chance this could be fixed without pulling the tranny?
i estimate my motor to make about 280hp, is this enough to kill an older 700rr (pre-87 or whenever they made some changes)?
Thanks!
Old Sep 12, 2006 | 02:18 PM
Re: weird 1-2 shift, 700r4
anyone?
Old Sep 13, 2006 | 03:31 AM
Pro Built Automatics's Avatar
If you have not burned the 2-4 band yet, you could add a Corvette servo, and a larger main & intermediate boost valves. This "might" solve the problem. If it does not, you will have to go into the transmission to solve this, as the 2-4 band & the reverse input drum will need to be replaced at a minimum. If you have to go into it, then locate a 1988 & up transmission to start with. These are a better transmission to start with for a performance buildup.
Old Sep 13, 2006 | 05:30 AM
Honda Hunter's Avatar
How do you use a 98 tranny in a 700r4 car?
Old Sep 13, 2006 | 09:41 PM
it was a broken 1-2 accumulator spring, picked up a new one from a local trans shop along with a 'vette servo. put the new spring in now it shifts great at partial throttle but still has a slight slipping feeling at wot though. the 2-3 shift is great at all throttle openings. the 'vette servo has yet to go in becaus i'm having a hell of a time getting the lock ring off of the cover.
Edit: do larger boost and intermediate valves come in a transgo shift kit? also is the transgo servo different from a gm 'vette servo?
Old Sep 15, 2006 | 06:47 PM
little help with the shift kit stuff? i looked at transgo's website and they don't say what comes in it.
Old Sep 15, 2006 | 11:40 PM
The Corvette servo will help out, once you get it in. The servo from Trans-Go is the Corvette servo. Depending on which kit you get, they can come with the larger boost valves. The "modified" Trans-Go Performance Shift kit comes with the larger boost valves, Corvette servo, the accumulation for 2nd gear (smooth part throttle shifts), Torlon replacement checkballs, etc.
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
marlar98
Sep 19, 2015 07:53 AM
92_RS_305
Sep 8, 2015 07:47 PM
CARiD
Sep 7, 2015 08:21 AM
