Washer for torque arm?
Old Feb 8, 2007 | 04:04 PM
Jazsun's Avatar
After doing a clutch job I noticed a washer had fallen off of the torque arm or rear end couldnt tell where it went or why there was just one. But it went on one of those huge bolts that go attach the TA to the rear end. Which one does it go on, and does it go on the top where the nut is? Ive been driving it for a while but every once in a while I get a pop from back there on takeoff.
Old Feb 8, 2007 | 04:07 PM
2000GTP's Avatar
The bolt goes through the bottom and the fastener nut goes on the top.
Old Feb 8, 2007 | 04:44 PM
Stock, the bolt goes in from the top and the nut and washer are on the bottom.
Old Feb 9, 2007 | 04:50 PM
Jazsun's Avatar
There was only 1 washer on one of my bolts when I took it off wierd....So there are suppose to be two washer, one on each?
Old Feb 9, 2007 | 05:41 PM
OBE1 95Z28's Avatar
For safety factor, I would recommend that the bolts be installed as Shoebox points out above. This way if the nuts work loose, you won't loose a torque arm (at least right away)
Old Feb 11, 2007 | 02:08 AM
Z-RATED94's Avatar
I'll have to agree on that, and that's how I installed my Spohn TA.
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
