vibration, is it pinion angle?
Old May 18, 2005 | 04:16 PM
  #16
OutKast's Avatar
Re: vibration, is it pinion angle?
if it wasn't happenning before the new rear then I don't think the rotors are likely to be the cause.
Old Jun 26, 2005 | 04:21 PM
  #17
Deenasty's Avatar
has anyone got an update on this? I am having the exact same problem. I am running a 12 bolt with the Spohn Torque arm, stock balanced driveshaft. So does the driveshaft have to be shortened? I feel the vibration right at the transmission/center console area. But it sucks. I feel it really bad right around 60-65. At 70 mph it lessens. Any ideas?
Old Jun 28, 2005 | 10:52 PM
  #18
OutKast's Avatar
I should have my new driveshaft very soon. I'll let ya know if that takes care of it.
Old Jul 13, 2005 | 07:26 PM
  #19
Janny's Avatar
I've got bad vies too, so please keep us informed. Mine shakes like hell at about 80mph and just doesn't let up. I barely notice it until I get to 75 mph.
Old Jul 19, 2005 | 08:49 AM
  #20
OutKast's Avatar
the new driveshaft fixed my problem...smooth as butter @ 120+. I went with a new DS from Denny's . Not only do they back their shafts like no one else I've seen but this was hands down the #1 customer service experience I've had.
Old Jul 19, 2005 | 11:28 AM
  #21
Deenasty's Avatar
Bingo, you got it. I took my driveshaft to my friends place to have it rebalanced, for the second time, adn it was way off. My friend has been in business for 25 years, and all he does is driveshafts. He said that if you notice the "harmonic balancer" looking thing on the front of the driveshaft, he said those were placed on the driveshaft to absorb small vibrations, from the sloppy balance job that GM preforms on them from the factory. Well turns out, these "balancers" are pushed in and held together through a rubber bushing. He said with just enough power, you can spin the driveshaft, and the balancer would stay steady, causing the driveshaft to unbalance itself. He told me to retry mine, and if no luck, im going with a Denny's as well.
Old Jul 22, 2005 | 11:45 AM
  #22
97LTImike's Avatar
I think you had mentioned the vibration continuing even when you were'nt in gear? Could that be engine vibration and not DS, Pinion angle or wheel balance? I had a buddy who had vibration and spent a ton of money trying to pin point the problem. He finally realized it was an engine mount that had broke.
I have vibration as well after I changed my tranny mount to a poly, by Energy Suspension. Pretty sure mine is an unbalanced harmonic balancer. Possibly a chasis dyno can help give you more answers.
Old Jul 22, 2005 | 05:53 PM
  #23
Joe 97RA's Avatar
Mine was perfect until I lowered the car. By dropping the rear ride height, the pinion angle was changed. It ended up being roughly +1º.... the vibration was worse with added weight in the rear, confirming yet an even greater change in pinion angle. I adjusted the torque arm for -2º and no further vibrations.
Old Jul 22, 2005 | 09:29 PM
  #24
Janny's Avatar
Originally Posted by Joe 97RA
Mine was perfect until I lowered the car. By dropping the rear ride height, the pinion angle was changed. .
Joe, how much did you lower your rear end. Mine is down only one inch.
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
