Vibration at highway speeds
Old Aug 4, 2008 | 02:54 AM
twcblackhand6970's Avatar
I just got my car back today and while driving on the freeway at about 60-80mph (80 being the fastest I went) the car began to vibrate in the passenger compartment, being strongest under the center console. The vibration only at high speeds. And the vibration seemed to be in pulses. What could be giving off this strong vibrations?
O'yea, and seems a lot stronger when I'm decelerating.
Old Aug 4, 2008 | 11:29 PM
Fatdog2's Avatar
Might check the tires(balance) (back tires). .Drive shaft?
Old Aug 5, 2008 | 01:14 PM
slomarao's Avatar
Driveshaft needs to be re balanced. Also re do the tires while your at it.
If its not either of the two i would check out all your bushings and rubber. LT cars are old.
Old Aug 5, 2008 | 03:47 PM
Green96Z's Avatar
I have the same problem with mine. First check your tires for balance. Next would be the driveshaft. Check it for balance. If it checks out (like mine did) then check the u-joints. Start with those and see if you find anything.
Old Aug 7, 2008 | 11:34 AM
bluz28's Avatar
Lightbulb
Check your pinion angle, mine was doing the same thing with a pulsing vibration at freeway speeds. After I checked, then adjusted the pinion angle a little(-1 degree) the vibration is gone!
Louey
Pacific
Apr 28, 2015 01:05 AM
Louey
Pacific
Apr 7, 2015 02:10 AM
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Dec 8, 2014 08:01 PM
