Vibration at 50mph in third gear in A4
Old Aug 27, 2010 | 01:48 PM
Hyphy01SS's Avatar
Exclamation Vibration at 50mph in third gear in A4
Hey guys, i have a little issue that worries me. I dont think theres is anything broke or messed up since the car has only 60k on the clock now, but when im going down the highway doing in between 50 and 60 in drive i got a slight howl and whine but after about 70 it goes away and you only hear it if i accelerate from about 55 to 65 then its gone. Im sure thats just how the rear end is because ive seen other cars do that, but the other concern is when im going in between 50 and 60 and I drop the selector into third I get some slight vibrations and slight shakes, but there barely notcieable and its more pronounced around 50 to 55 but only when I drop into third, when i go back to overdrive it goes away. Is the rear end due for a fluid change and some good quality fluid, or do I need to check and see if the u joints and the driveshaft are properly torqued on all the bolts. If anybody is ever had an issue like this please chime in. Thanks alot.. BTW- Tranny fluid is brand new with a new filter.
Old Aug 28, 2010 | 10:21 AM
n2ceptor's Avatar
A howl or whine is generally the diff... As for vibrations, it might be the trans mount...
Old Aug 28, 2010 | 12:02 PM
Hyphy01SS's Avatar
Ok. When i'm checking the trans mount, am I looking for cracks in the mount and dry rotting? Thanks
Old Aug 28, 2010 | 01:38 PM
n2ceptor's Avatar
Yes... Its common for the mount to go bad... Why??? Wear and tear I guess...
Old Aug 28, 2010 | 02:07 PM
SROACH's Avatar
My trans mount was horrible! I pick up a Energy Suspention one for $30.00 at Autozone.
Old Aug 28, 2010 | 03:56 PM
Hyphy01SS's Avatar
Did it cause the car to make the vibrations and thing im feeling at those speeds in third?
AdsoYo
May 2, 2018 03:21 AM
Apr 16, 2015 09:57 AM
Rde Bandit
Mar 21, 2015 10:17 PM
karnykamaro
Feb 2, 2015 01:37 PM
mattszm6
Dec 14, 2014 07:09 AM
