Valvoline Max Life ATF
Old Feb 18, 2006 | 11:07 AM
Silver's Avatar
Anybody tried it? Wonder if it's just another gimmick or if it's comapable to the motor oils of said trend. I sortof feel like you shouldn't experiment with the tranny like you do the engine with oils so I don't wanna "try" something that may not work. Too much work to change it if it acts funny.
My car has 110k, I'm going to change the tranny filter for what is most likely the first time ever. I had it flushed at about 75k. Pulls good but wants to get stuck in between gears when going around curves and accelerating.
Old Feb 18, 2006 | 02:19 PM
GreenDemon's Avatar
Re: Valvoline Max Life ATF
What do you mean, "stuck between gears"?
Anyway, Valvoline makes good products. Most high mileage products have extra seal conditioners to keep them from becomming brittle, probably other stuff I have no clue about.
Old Feb 18, 2006 | 02:36 PM
Silver's Avatar
It doesn't leak so I sortof discount the seal conditioner benefit.
When going around a curve and accelerating, it's like riding the clutch in a stick - it won't grab. RPM's will climb (not uncontrollably) and if I gas it it'll grab one of the two gears it's searching for. When it grabs it grabs good, no slipping feeling...
I used the term b/c it was an accurate "what it feels like" description, not what I think is literally happening.
In a straight line, I have no problems at all, even at WOT, but during a curve, accelerating, it'll do it with the least amount of gas.
Old Feb 18, 2006 | 05:35 PM
angel71rs's Avatar
Does 95 have electronic tranny or is it still controlled by a TV cable? If it's cable, try adjusting it.
Old Feb 18, 2006 | 06:56 PM
Silver's Avatar
electronic
Old Feb 18, 2006 | 11:35 PM
Honda Hunter's Avatar
Last time one of my trannys did that it only got worst. A week or two later I started losing gears. Had to be rebuilt.
Old Feb 19, 2006 | 12:52 PM
Silver's Avatar
woo hoo...
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Sep 18, 2015 03:46 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
