V6 and V8 rear end any difference?
Old Oct 2, 2010 | 04:26 AM
roadkillZ28's Avatar
I found a wrecked 98 V6 camaro with GU6 witch its rear-end supposed to be 3.42 ratio so now I'm wondering is it possible to swap my 3.23 rear-end with a V6's one?, Is there any difference between LS1 and V6's rearend? Mine starts screaming on highway (long time) so it time to replace it?
I already did a search I did not find a specific answer
Thanks in advance
Old Oct 2, 2010 | 04:32 AM
Procharged94Lt1's Avatar
Should be an easy swap out- just have to get your computer reprogrammed for the new gear ratio.
Old Oct 2, 2010 | 11:57 PM
Thank you! yes your right I should reprogrammed for the new set ...
Old Oct 3, 2010 | 10:19 AM
May or may not be a posi.
Old Oct 3, 2010 | 02:56 PM
Not sure really I will check it tomorrow however looks alike with my rear-end both have ABS sensor on the top, in fact I don't care weather its a posi or an open diff. GM calculation was suck for 10 bolt anyway , I just want to get rid if whining sound from my car
Thank you
Old Oct 4, 2010 | 04:17 AM
Well it's a posi I need to change its lubricant do you know what type of lube is suitable? Not sure weather eaton or aurburn...
Old Oct 4, 2010 | 07:49 AM
AL SS590 M6's Avatar
Moderator
If it's a stock rear 93-98 it has an Auburn, if it's a 99-02 then it's a Torsen and synth 75-90/80-90 with a bottle of friction modifier will do for either one.
Old Oct 4, 2010 | 12:02 PM
Thank you
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
