using N20 through shifts?
yea... id go window switch if i were you, or at least thats what i plan on doing... oh wait it probably wouldnt be spraying anyways if you are using a WOT switch
i dont know let the nitrous experts give their opinion, but id still use the window switch
oh wait.. just noticed you were an a4 nevermind about that last part... experts?
I dont see why I couldnt spray through shifts? My engine is bone stock. Im starting out with a 75 shot and moving up to 125 shot so it would be like shifting with 350 crank hp and 400 crank hp. I just had my trany rebuilt and a 2200 stall converter. My trany guy runs a big block with 400 plus hp through the same tranny.
With the a4 and depending on your gear if your window switch is set at 3000-5900 your not going to be off spray but 100ish RPM's between shifts. When you hit the next gear you will be above that 3000 mark. I dont see how the extra spray during shifts will gain that much but I could be wrong
Really, how much time is lost, or gained depending on how you look at it, if you don't spray through the shifts? Even with a built trans, why look for trouble?
I have some that spray through the shifts, but if you can use the "window switch" effectively, yes, it will be easier on the transmission.
WobblySausage
Oct 7, 2015 10:09 AM
