unblocking "blocked" accumulators?
Old Sep 2, 2009 | 06:19 PM
LearJet's Avatar
The *******s that built the trans I am currently running advertise this:
"We block off the 1,2,3,4 accumulators to give you a solid, firm, and crisp shift. We discard the springs in the accumulator to eliminate problems associated with springs breaking".
I just bought a transgo hd2 reprogramming kit and my question is can I undo whatever it is they did in order to install this kit? If not I still have the original core, I should be able to swap the entire valve bodies assuming they are the same, correct? The only thing I am not real sure about is the 4th accumulator bore seems to be part of the case and if they drove a check ball or something in the bottom of it I may not be able to remove it cleanly. Also while on the subject of the reprogramming kit I am running a fairbanks/sonnax 2-4 servo combo, should I leave it as is or install the servo parts included in the kit with it?
Old Sep 2, 2009 | 06:39 PM
Performabuilt's Avatar
Supporting Vendor
I would not worry about the 4th accum myself as the TG kit has you flip the accum pver anyway so it is technically blocked since it just fills with fluid even if its also blocked mechanically
Old Sep 2, 2009 | 07:19 PM
LearJet's Avatar
what about the forward accumulator and the 2/4 servo?
Old Sep 3, 2009 | 09:49 AM
Supporting Vendor
THE Forward accum should be left alone. the 2/4 servo set up acording to whatever servo set up your usings instructions. I would put a metal piston in the forward servo if not present however
Old Sep 3, 2009 | 01:22 PM
LearJet's Avatar
So don't put the transgo kits 2/4 servo parts in then, leave it as is. I like that because now I don't have to drop the trans down to put the kit in.
Old Sep 3, 2009 | 04:54 PM
Supporting Vendor
I generally do not do that and wjile i do use te larggest feed hole sizes in plate i gnerally set the 1-2 accum to stock also
G-BODYT56
Jan 14, 2022 11:14 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Schearer225
Aug 2, 2004 08:14 AM
zo6vette
Aug 20, 2002 01:34 PM
