Transmission woes.....
Last night, I was coaxed into doing a "little" burn out when I had left from picking up my girlfriends' daughter. After about 80 ft. and much smoke and two nice stripes :D , .I let off the gas and rolled out the rest of the way to the stop sign. I shifted from 1st into OD. When I left from the stop sign, I no longer had 1st gear. I can get first gear if the selector is in 1st, but that is the only way! To make things worse, I turned onto I-43 southbound and accelerated "quickly" and I had no OD:eek: . I had to drive from Greenbay to Germantown( just north of Milwuakee) in third or Drive. It was a long and very loud ride with the engine turning 3200 rpm all the way!!!
I'll break out the GM service manual and begin looking but I am open to suggestions... any help is appreciated. A little info on setup: Stock 10-bolt 3.23 gears stock 4l60e w/ shift kit Edge racing converter 3400 rpm stall tranny cooler PCM for less tune |
Re: Transmission woes.....
mine is doing the same thing shut your car off and restart it and all the gears are back not sure what problem is but i want to know
