Transmission Clutch Master/Slave removal
Old Nov 5, 2011 | 01:25 AM
Drur619's Avatar
Currently, I'm replacing the clutch in a 95 z28 lt1 6 speed and have come to a possible problem, maybe. I began to take the Clutch Master/Slave off and as I started to remove it the piston began pushing it out. Is this normal? Should I go ahead and remove or might it be a cause to the problems? When pushing the clutch peddle in it would have a grinding sound so I figured it was throwout bearing? Any replies would be awesome. Thankyou.
Andrew
Old Nov 5, 2011 | 04:50 AM
97WS6SCharged's Avatar
Re: Transmission Clutch Master/Slave removal
There should be a little bit of pressure on the slave, don't worry about it pushing itself out as you remove the nuts.
Old Nov 5, 2011 | 07:22 AM
bw_hunter's Avatar
As Chris mentioned, it is pretty normal to push out a little. You can easily overcome it when it comes time for reassembly.
Just be certain to NOT press the clutch pedal with the slave cylinder off....you'll destroy it. I mention this because someone I know decided to test for a funny noise by working the clutch....
Old Nov 5, 2011 | 08:31 AM
Drur619's Avatar
Thankyou 97WS, and Hunter, very much. Hopefully I'll have it put in and back together here shortly today. It's not as complicated as I thought, so far. Thankyou again.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
BigWil
Mar 29, 2015 12:24 PM
HectorM52
Jan 30, 2015 11:08 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
