transmission
Why not just swap in a T56 then? I understand that you have these parts just sitting around but if you are going to do something like this then you might aswell do it right and with a transmission that was already meant for the car.
I'd recommend selling parts from the '79 and buying a T56 with the proceeds.
It could take a whole winter if they had to rig up a clutch cable and shift linkage, fabricate a bellhousing, figure out how to make the speedometer work without an electronic speed sensor on the transmission (or retrofit a speed sensor on it), etc.
