trans-trouble
Dear Oracle , I am having trouble shifting my t-56 at full throttle and at5K+ revs. If I am hard onto the power side of the gear the trans. tends to reject the shift. If I "float" the shift, all's well. This occurs on up and down shifts. I recently changed the fluid to a synthetic type, not much difference.The car has 87K miles and I do not think the trans. has ever been touched .I now throw myself at the temple entrance and await your [TEKE] comments.
1SlowFormula, Thank you for your response. I suspect the syncro's as well to be the culprit. Now...if I have to replace the 6spd , should I consider an "up grade" if practical? Are there some better than others exchange units? Any info appreciated. Thanks in advance ckid
Re: trans-trouble
i'm still kindda new to the internals of the manual trans....which i am currently researching since i have a nasty grind in mine
but i agree...sounds like the synchros.
maybe give a shout to t56rebuild.com and see what those guys say. i looked and i think a basic performance rebuild is about $1000
