Trans probs !! Help !!
I installed a Vig 3,200 converter about a week ago . Well here's the deal , Coming home tonite from work , i jumped on it and it didn't shift to second it hit the limiter and i backed off and then i think it shifted . After that it was acting funny , it won't shift t 2nd and when it does it feels like Neutral untill you get the RPM's up . And ive also notice it won't go into reverse but acts fine in first gear . I should also say ive never felt it slipping ever and the car has just over 70 k on the clock , im thinking either the converter is bad or the front pump , it makes a wine-ing noise like maybe a pump , any help guys??
Re: Trans probs !! Help !!
have u considered checking your solinoids?
did you reprogram your pcm?
Mine is doing something similar, but I have a stock converter. Mine doesnt want to shift to 3rd though. It stays in 2nd and I have to rev it up a few times (in the neutral mode) and it eventually catches and shifts to 3rd. I am going to have it rebuilt, again (only like 5 months on last tranny rebuild). Hope you figure it out and you dont need it rebuilt. Good luck.
Benji
Benji
ricks95TA
Jul 23, 2015 12:59 AM
