Trans problems please help
Old Jun 22, 2004 | 10:21 PM
mullettour's Avatar
Since installing my converter I hadn't brake stalled it to see what it would stall up to and I have been curious. In order to find out I put the shifter in second to keep from spinning the tires in first. I held the accelerator to the floor and let the transmission stall up. After doing this I let of the accelerator and the brake and let the car roll forward. I then put the car in drive and it would not shift out of 2 gear no matter what drive position it was in(1-2-3-D). Could I have set a transmission service code causing it not to shift. If so what can I do to fix it. I have the battery disconnected in hopes to clear any codes that have been stored. Please help if you know what happened to my trans.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
Sarahrope64
Nov 27, 2014 11:17 AM
siguy
Nov 27, 2014 10:07 AM
