Trans help
Old Sep 2, 2003 | 12:34 AM
Green97RS's Avatar
Trans help
i recently bought a 93 Formula auto, i noticted that it does not shift at redline. At WOT it shifts at around 5200 RPM into 2nd gear and into 3rd gear. when it shifts inot 4th its at around 4300 RPM at WOT. it seems to shift at around 5500 when its running cold , like when it sits overnight. once the motor heats up it shifts at 5200. no i know my car has a 4L60 and is not computer comtrolled and is controlled by the T.V. cable. I took it to a trans shop and they couldnt find anything wrong becasue they would run it when the motor was cold. does the cable need to be adjusted or is it somthing else?
Old Sep 2, 2003 | 08:46 PM
viperkiller's Avatar
4l60e and 700r4 are the same trans.
4l60 is just controlled by the pcm 700 isnt
by adjustind the t.v. cable you can change the shift points
move it a couple clickes at a time and check it
Old Sep 3, 2003 | 11:59 AM
Green97RS's Avatar
how do i adjust the TV cable?
Old Sep 6, 2003 | 10:57 PM
Green97RS's Avatar
had my mechanic check out my car today, and he said that the TV cable is in the right postion and that its not the problem. does anyone have any idea of what the problem could be?
Old Sep 6, 2003 | 11:22 PM
Fatdog's Avatar
Cool
Yes.First change the coil wire.If that helps,then it's plug and wires time.Be prepaired to change the wires about every couple of years or so,but the coil wire must be changed about every 6 months or so as part of general maintenance.Also.if the car isn't getting enough air,then install a better intake air system.If your cat is going south,then that to will cause the quicker shifting.It seems the trans listens to the engine for advice,even though it's not electric.Agood running engine will make the trans shift better.Hope this helps.(Maybe the horse power is dropping off,so the trans has nowhere to go but shift.)Well,the guys in the white coats have arrived,gotta go now.My02
Old Sep 6, 2003 | 11:26 PM
Fatdog's Avatar
Cool
Da,97's are electric.Sorry,just got off the boat.Anyway,if the engine isn't running right,you can feel it in the trans.(check the wires and the plugs.).Whew.
Old Sep 6, 2003 | 11:48 PM
Green97RS's Avatar
did you think i was talking about my RS? im talking about my Formula. yeah the cat might be bad, the heat sheild on that thing has started to rattle so maybe its time for a new cat.
Old Sep 7, 2003 | 10:54 AM
Dave89IROC's Avatar
83-90/91 was 700R4, hydrauliclly/ mehanically controlled shifting, uses TV(throttle Valve) cable for engine load input
90/91-93 was renamed to 4L60, same trans as 700R4
94 up was 4L60E, E means it is a 4L60, electronically controlled shifting, uses TPS to PCM for load input(also involves MAP/MAF and VSS)
force10
Aug 10, 2015 08:30 AM
ricks95TA
Jul 23, 2015 12:59 AM
jackpawt883
Jul 20, 2015 06:32 PM
dolfan324
Jul 17, 2015 10:34 PM
Fastbird93
Jul 11, 2015 04:37 PM
