Tranny Trouble
Old Sep 4, 2007 | 08:48 AM
350pride's Avatar
Tranny Trouble
How can I tell if it is the torque converter or the transmission?
I put a used torque converter in my car about 4-6 months ago...will after about a week it started making bad vibrating/poping noises at idle conditions...but anything above 20 mph and it would go away...performance was fine so I disregarded bc I asked the guy who put it in and he said that he did not know...(I know)...well now 4-6 months later I go to give the car hell and it flashes up to 3500 rpms and you can feel it start to pull but then it stops just feels like you popped it into neutral...and it does it no matter at whats speed you do get on it at. But the car is driveable...as long as you are being nice...so is it the torque converter or the transmission?
Old Sep 5, 2007 | 06:30 PM
350pride's Avatar
help?
Old Sep 5, 2007 | 11:57 PM
Performabuilt's Avatar
Supporting Vendor
Could be the one way clutch in the converter or could be the trans I would pull the pan and then tell us whats in it.
Old Sep 8, 2007 | 06:23 PM
350pride's Avatar
ok so have not had a chance to drop pan but I smelled the transmission fluid and it smelled burnt...my mechanic friend told me that this means the transmission is gone
any comments?
Old Sep 8, 2007 | 07:41 PM
Supporting Vendor
If the trans smeels burned and the symptoms you describe I would say you need a trans.
Old Sep 9, 2007 | 08:07 PM
350pride's Avatar
I saw on your website that the level one trans has a "bite" at wot...what does that mean as appose to a stock tranny with a shift kit and a 3600 stall...
Old Sep 9, 2007 | 08:13 PM
Supporting Vendor
Its means it will have a very firm shift at WOT like the shift kit you mention and it will have comfortable but firm shifts at lighter throttle opening.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
