Which tranny fluid and how much?
Originally posted by hot_red_z28
yes, as long as you have a 4L60E, the gasket is made to fit the trannies bolt pattern... As long as your aftermarket pan has the same pattern, you shouldn't have any trouble at all...
Originally posted by RobbyRob
Synthetic atf is made with friction addative's that will give you a quicker and a stronger shift. They didn't make it not to out perform standard atf .
