tranny
No you cant turn the converter and flex plate because you do not have the converter fully seated in the pump , As was said above remove trans and try again , Even if you do get the converter bolts in your going to break the pump when you start the car ,
. You can run the engine with the transmission in anything from Park, to Neutral, to Drive, right?
This isn't a manual with locked in GEARS.Now, get back out to the garage and start pulling that b!tch apart!!
