traction was bad before.... with cam forget about it! HELP!!
Old Dec 4, 2003 | 08:18 PM
96 WS6's Avatar
Okay my traction, well actually that's an oxymoron. The word "My" and "Traction" should not be in the same sentence. I have stock LCA's with no relocation brackets and crappy kumhos. I was thinking reinforced stock LCA's with reloc. brackets and drag radials. Would that make me hook? I was even considering an airbag on the pass. rear. How much would that help? How expensive is it?
What are my options. I need to get traction because I'm not going losing to cars that are way slower than mine and not be able to run 12's because I'm spinning the crap out of my kumhos.
PS - Spinning the tires is fine, but sometimes I want traction!!!
Old Dec 4, 2003 | 09:50 PM
samdogmx's Avatar
et streets
Old Dec 5, 2003 | 12:40 AM
96 WS6's Avatar
I'd need a 12 bolt for that, which I do not have
Old Dec 5, 2003 | 03:27 AM
AL SS590 M6's Avatar
Moderator
Your planned mods will do the trick nicely.
Old Dec 5, 2003 | 04:44 AM
IllusionalTA's Avatar
drag radial's will help you hook for the most part in decent warmer weather
Old Dec 5, 2003 | 11:07 AM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Tires.. get some nitto drag radials
Old Dec 5, 2003 | 01:13 PM
96 WS6's Avatar
Thanks for the responses. I will be doing the LCA+Reloc very soon. As for DR's it's winter now I don't know if I want to do that. Maybe after it stops raining...
In the meantime, what is your opinion of airbags?? Do they work? Do you need to tote a compressor/tank around or can you just fill it to a desired pressure and leave it in the spring?? Where can you get a setup to fit an F body??
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
Amshnock
14
Jan 18, 2015 11:47 AM
jp2002ls1
Jul 22, 2002 04:18 PM
