torque converter installation
Old May 28, 2005 | 04:04 PM
BLinindoll's Avatar
Having problems getting 3 drops. We got 2, but have been working on the 3rd for about 3 or 4 hours. Tranny is stood up on end. Tried lifting, droping, twisting... everything... it won't drop in. Need help ASAP, as we are waiting by the computer for help.
Old May 29, 2005 | 01:47 AM
revtime's Avatar
Re: torque converter installation
It may be too late.......but what I did was just kept rotating the coverter until it dropped.
If all else fails get it on as far as you can and then get it up on the block as long as you have clearance to spin the converter after you get the bellhousing bolts tight you should be good to go. If its tight against the flexplate and you cant spin it then it needs to go in further. Be careful if you try this, watch closely and check often as you tighten down the bellhousing bolts.
It can be tricky, you should also have a measurement that came with the instructions as to how much gap you should have between the mating surface of the bellhousing and the mating surface of the converter.
I can,t remember it off the top of my head, my trannys been in 2 years and I am getting old.
Old May 29, 2005 | 06:33 AM
BLinindoll's Avatar
yeah, we spun it for a while, but it still didnt drop in. it bottoms out on the flexplate before the bellhousing meets the block.... it still has to drop one more time... its just not going no matter what we do. the measurment your talking about is supposed to be 1-3/8" i believe. its only about a half an inch right now.
Old May 30, 2005 | 01:48 AM
revtime's Avatar
I know you have tried this but pull the converter back off spin 180 and drop it again.
It will go you just have to keep playing with it. Keep the part that inserts into the front seal lubed up with tranny fluid.
Try pulling it up slightly as you turn it, perhaps the front pump is turning as your turning the converter, pull up slightly turn and then back in.
Just throwing some ideas out there.
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
StansZ28
Feb 19, 2015 07:39 AM
PCLZ28
Parts Wanted
Feb 12, 2015 11:35 PM
Collector Car
Dec 17, 2014 01:12 PM
