Torque Converter holes not lining up with TCI flexplate.
Old Feb 9, 2008 | 05:41 PM
Sunsetmaro's Avatar
Ok I went ahead and installed my new TCI flexplate because my old stock one was cracked in three places. I bought a YANK ss3600 torque converter and put it in. After I put the tranny back up and bolted up, I went ahead and tried to line up the holes for the flexplate and stall so I could bolt it up. When i tried to, the hole wouldn't line up, I can spin the torque converter and turn the flexplate with a screw driver so its not like I can't line it up, and I spent about 30 minutes just trying to see if I screwed up anywhere. Now I heard you might have to drill out the whole for the flexplate, is that true and has anyone done it? Im sure theirs someone out there that has a tci flexplate and Yank stall, I can't see using that paper thin flexplate and a large stall. WILL I NEED SPACERS??!?!?!?? PLEASE HELP. i want to finish this up tomorrow!!!
Old Feb 9, 2008 | 09:42 PM
AL SS590 M6's Avatar
Moderator
My TCI flexplate has 2 complete sets of holes. If the tc won't line up turn the flexplate to the next hole and it should work for you.
Old Feb 9, 2008 | 09:46 PM
BMoney's Avatar
they have a small bolt pattern and a large bolt pattern. you have to find out which one you have. most aftermarket flexplate's should have both.
Old Feb 11, 2008 | 12:24 PM
Ken95Z28's Avatar
If its the SFI one you will need to clean up the holes with a drill. Mine was very tight before I cleaned it up. I also test fitted mine to the converter prior before installing the flywheel.
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
StansZ28
Feb 19, 2015 07:39 AM
PCLZ28
Parts Wanted
Feb 12, 2015 11:35 PM
Collector Car
Dec 17, 2014 01:12 PM
