torque converter bolts??
Old Sep 5, 2006 | 03:54 PM
b.lee's Avatar
Arrow torque converter bolts??
sorry for the newb-ness but, does a torque converter have bolts that hold it in or down or something? (in my 98 auto z28)
cause i have a viberation at the top of every gear, and when i rev it up parked either in park or nuetral.... could this be the 'torque converter bolts'?
some local mech. said this is a common problem among f-bodys and vettes and there is a plate that removes so you can tighten up these bolts...
I thought he was talking hot air, what do you guys think?
Old Sep 5, 2006 | 04:02 PM
king1138's Avatar
Re: torque converter bolts??
yes, there are bolts that hold the torque converter to the flexplate. there should also be an access plate on the very bottom front of the transmission that is removable to access these bolts. remove this plate, and rotate the engine by hand to access all the bolts. there should be three or four depending on the engine. you need to torque these bolts down, don't just assume they're tight enough.
btw, this is a very noob topic, but how else do you learn but to ask questions? good luck, hope that works out for you.
Old Sep 5, 2006 | 04:06 PM
b.lee's Avatar
you just answered my question.
I will have these bolts torque'd to spec.
helps me a ton! thanks.
anyone else's input is always welcome.
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
StansZ28
Feb 19, 2015 07:39 AM
PCLZ28
Parts Wanted
Feb 12, 2015 11:35 PM
Collector Car
Dec 17, 2014 01:12 PM
