torque converter
hello guys and gals
can you guys tell me what torque converter in the TCI brand is a direct replacement for my 97z 28. i would like to have something in the 2800 stall range. I am running 150shot,few mods:
Stay away from B&M, unless you like potential problems, TCI is a little better. Yank, Vigilante, are the best. Edge and Midwest are good from what I hear. Except for GER (out of busines from what I have heard), the B&M has the highest comeback ratio on torque converters out there. Remember when the TC goes, so does the transmission in most cases.
I put new bolts in, it is cheap insurance and yes it should bolt right up.
Make sure you get the converter to engage properly with the front pump.
Took me a couple of tries to get it right, I also poured 2 quarts of fluid into the converter before installing it on the tranny.
As far as I know all torque converters are a direct boltin, but you might have to drill the flywheel holes (3) alittle bigger depending on the size converter bolts they give you, some companies use bigger than stock bolts. No big deal thou.
