Tools required to rebuild th350?
Old Dec 24, 2007 | 03:36 PM
96ZCamaro's Avatar
I was wanting to know what all tools are required to rebuild a th350 transmission. Mainly meaning any special tools needed. Also is there any good guides or diagrams for these transmissions online?
Old Dec 25, 2007 | 07:27 PM
12SCNDZ's Avatar
You'll need a clutch pack spring compressor for the drums, and then another for the low/reverse spring pack, lip seal tool, straight snap ring pliers, 90 degree snap ring pliers, TH350 bushing driver set, pump alignment clamp, dial calipers, feeler guage, torque wrench. You'll also need an air compressor, to check clutch apply, along with many common hand tools...Hammer, channel locks, several flat screw drivers, a phillips screwdriver, a standard SAE sockets set, ratchet. You'll also need a tub of assembly lube and a tube of Permatex "Ultra Copper" silicone.
Look for the ATSG assembly manual. My regular parts supplier carries them.
Frank
CPT
Aug 24, 2015 06:41 AM
karpetcm
Aug 14, 2015 03:02 PM
Aug 7, 2015 08:52 AM
wesley81
Jul 27, 2015 11:31 AM
